THOMAS'S WEB SITE
Date:  7-26-2016
Number of Hours:  6.00
Brief Description:  Nosewheel and Rudder Steering
Swaged the cables at all ends, covered the ends with shrink hoses. Drilled and bolted the 2 pulleys into position. Thereafter I cut 2 little squares into the fuselage trailing edge to accomodate the rudder steering lever, in order to allow a rudder deflection of plus/minus 25°. For the time being, I'm not sure yet what represents the dead end at 25°. Contacted my builders support and some other sources.
Rubber Hose to Guard the Wire through the Holes
